Will this work?
Nasby
Ohio
I have a PRO-96 which won't do LTR trunking. Will it work if I simply program all of the frequencies in a particular LTR system in conventional (non-trunking) mode into my scanner?
Thanks in advance.
captclint
Mountaintop, PA
Definitely. However, you may miss parts of conversations that are switched to free repeaters, and you will have more difficulty trying to figure out who the various users are without TGID's. I did that for several months before I finally decided to get a new scanner, and I had over 30% of the users identified without TGID's.
Colin9690
County 21
APE282018
If it's not a busy system it will work fine. It only switches to a free repeater if the home repeater is in use, and if it's not a busy system, chances are the home repeater won't be tied up. So, if it's a very busy system, it will be hard because of all the repeater switches.
