Win 500 Wildcard Question
swann3030
North Tonawanda
When I add a wild card to a trunked system it defaults to scan list 1. Is there a way in Win500 to change it to the scanlist of the trunked system?
04Z1V6
Castle Rock, Co.
Yes, open the (TSYS Objects folder) goto the last entree in your (TGRP field) and highlight the last entree, then when this is highlighted press ctrl+shift+N on your key board together or goto (Edit) and click on (New Item at end) this will insert a new wildcard and you can assign it to this scanlist by going to the right of the (TGRP list) under the header (Scan list) uncheck any unwanted scanlist number and check the list you would like it in. You can then upload it in the scanner and don't forget to save this if you would like to make it a permanent part of your program.
