Win 92 question
RCMSE
rural Sapulpa
I just bought a pro 92B from e-bay. Too much to program by hand! So I'm building a two-way cable from Bill's site.I have downloaded WIN 92.
My question is what do I do now? How do I send and recieve imfo. to my PC.What's the trick?
OkRob
On Win95, you select Scanner from the top menubar, then Download from Scanner or Upload to Scanner. Not sure it is the same in Win92, but the screenshot of Win92 looks the same as Win95. Hope this helps.
- Rob
K5MAR
Stillwater, OK
Good luck with the cable! When you get going with Win92, first you'll need to click on the Configuration dropdown menu and setup the Serial Port. There are several items there you can experiment with to make the cable work, plus of course you need to set the proper serial port.
Then you can click on the Scanner dropdown menu, and either transfer the scanner's contents to the program, or send what you have already set up to the scanner. I'd suggest manually entering a few freqs into the scanner, and trying to transfer them to the program, just to make sure your cable and setup will work. Once all of that is functioning, you can start putting your freqs into the program, save it, and loading it into the scanner.
Mark S.
