WIN500 Object error
Webodisk
Silent key.
Virginia Beach,VA
Whne I try to upload my file to the scanner a window pops up say on or more objects are duplicated or invalid, win500 500 will fix this yes or no
any idea on how to find the problem object ?
Mike
DonS
Franktown, CO
That error means that either you have an object ID that is used more than once (they must be unique), or you have at least one object ID greater than 1851.
In the "All Objects" tab, click the "Show All" button. Then right-click on the "ID" column heading and sort in ascending order. Look at the bottom of the list and see if you have any IDs greater than 1851. You can also scan through that list to see if you have any duplicates (Win500 won't usually let you create duplicates).
Webodisk
Silent key.
Virginia Beach,VA
I have a lot above 1851, when I did the download from my pro 96 they were created by the program, all fixed d/l scanner saved file and problem is gone thanks Don
Mike
