GRE, Motorola, Rebanding, Tables, etc
A while ago on the GRE Forum there were posting about the time lag on the GRE line of scanners.
I saw that thread too, and they were discussing specifically a digital scanner (like the PSR-500). There are a lot more settings in the digital scanners, and they made some changes to defaults and resolved one specific issue.
Going thru some of these calculations even it is like a computer does take some time and I am wondering if this may be part of the time delay problem.
The 'problem' is that Motorola type systems only transmit a channel number and receivers have to do these calculations. Systems like EDACS use an LCN, which for scanners, does not require the calculations.
The problem I am having is my local Public Safety has just Rebanded and I know I am missing a lot of traffic but can not find the problem, its as if some of the Frequ. are missing.
Which system are you monitoring? Which scanner are you using?
There are all kinds of things that could be going on. I monitor 3 non-rebanded systems here pretty much 24/7 and find that I just don't have good reception on some specific frequencies; or at least the signals on those frequencies are not as strong for me as others on the same system.
In the case of rebanded frequencies, assuming a MOtorola type system, some issues are related to the specific frequencies being used by the system. Apparently the trunking table you use must be:
LO HI OFFSET BASE STEP
440 559 440 851.0250 25.00
000 719 000 851.0250 25.00
and in the order shown (440 first). This is a requirement according to GRE firmware.
I would like to be able to edit my own table, but I do not see a way to do it in WIN97. Perhaps WIN500 lets you edit/enter your own table.
