Win500 & Win96 in Windows 11
n4jri
Richmond, VA
Hi Everybody,
Computer keeps telling me to upgrade to Windows 11, but of course, I have these programs that I think were written for Windows XP. We seem to have survived in Windows 10. Anybody using them with Windows 11, and how's it going?
73/Allen (N4JRI)
a417
Hi Everybody,
73/Allen (N4JRI)
I do not use either of those programs, but I do have a large collection of vintage 98SE, 2000, XP software that worked in Win 10, and survived the move to Win 11 w/o an issue.
Here's a post with a possible fix to a potential issue, that is related to an update to the USB - Serial driver for your programming cable...but that issue pops up with nearly every older USB cable that uses that chipset. I would find the driver that is currently working for your win10 installation and make sure that you save a copy, in case win 11 decides you need to use their new hotness...which might make that cable not work.
gmclam
Fair Oaks, CA
As I sit here, I am running a system with each OS: Windows 10, Windows 7.1, Windows XP, Windows NT 4.0.... I am reply here using the XP Pro system. Last year I took a solid look at putting a new system into place and determined that everything I use won't run under the new operating systems.
Most of the stuff I use is shareware or equiv that I've licensed or code I've written myself. I was able to re-compile 2 programs to run under Win10, but most would have to be severly re-coded and there's little ROI for me to do that. The only thing that might be pushing me to "upgrade" is web browsing. I just don't use other stuff that requires someting newer.
The older WIN programs work on NT because they look for COM ports. But the newer scanners (lol-PSR-500 and later) require the newer USB cable and that requires XP or later. I do have WIN500 working on some Windows 10 laptops. But now the heavy lifting has moved to Sentinel; which I have installed under XP (and later). The key is having the correct USB driver installed for the OS you're using.
jaspence
Michigan
I have several CPS programs from various sources, and Windows 11 has not caused me any problems
