Win95 AM or FM
jimbo0706
Granbury,TX USA
I am Using Win 95 to program my Scanner.. Now when it comes to asking weather it is a FM or AM Freq.. How do i tell wich one I use.. Thanks in advance Jim
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Default is FM and all frequencies listed in the RR Database for Hood county are FM. I would just leave them at FM. However, your proximity to the Ft Worth Mot Smartnet should stir your interest to scan it. All you need is the 4 controls (red in the database) programmed, set them to Mot using the FM Pulldown beside each freq. Also set the Bank to Mot in the Type window near upper center of Win95. You can select up to 100 of the Talkgroups and enter them into the area on the right of Win95. Ignore the info above and to the right of Clear Trunk Info as Ft Worth is type II 800. You may want to use a bank just for that trunking system.
jimbo0706
Granbury,TX USA
Thank you all for the info.. But what I am trying to say is with the win95 I am putting in MilAir Was woundering if it was AM or FM But I guess I got my answer it is am since it is Air am I right ? What is the Mil Air Rang if some one could answer that.. :)
