Windows 10 complete backup?
arlo
I do not have a backup system on my Windows 10 desktop computer. Does MS one drive backup complete computer or just saved documents?
I have a Seagate GoFlex Desk USB 2.0 external hard drive form my XP. Can it be used for Windows 10?
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
One Drive is just a data backup, not for windows backup.
You need a program such as Macrium Reflect that does a full and complete backup of the hard drive.
Everything depends on how big your hard drive is and how much is on the hard drive.
Example: I have a 500gb hard drive and it has a total of 412gb on it. Programs such as Macrium do an image backup of the entire hard drive using compression. So my backup file is 177gb in size (compressed from 412gb). You also need another hard drive such as your GoFlex for the program to write a copy of the backup file with enough space on it for the backup copy. At least 1/2 to 3/4 the size of your original hard drive. A second internal hard drive for backup is much faster than an external USB drive.
(Note: you can NOT backup to the same hard drive)
Just a short answer to your question, it is not a hard process but you need to read all the directions of your backup software and understand the process it will take, BEFORE attempting to do a full image backup.
Blackink
Central Vermont
I use Macrium Reflect on 3 desktop computers and can vouch for how well it works.
You'll need a USB drive in addition to another hard drive, either in your desktop PC, or as an external unit.
I make back ups once a month on each computer and have used them twice on 2 different computers due to a hard drive failure and a corrupt operating system. It takes about 10-15 minutes to create the back up and if you need to use it, it'll take about 15 minutes to restore your computer (SSD or HDD) back to what it was like when you made the back up!
Macrium Reflect:
Rescue media and Windows PE: (I use a USB stick to put the Rescue media onto).
If you lose your Windows operating system, you can start your PC using Macrium Reflect rescue media on CD, DVD, or USB stick. This makes creating rescue media the first thing you need to do with Macrium Reflect. It contains a bootable, lightweight version of Windows and a full version of Macrium Reflect.
Disk imaging: (This is where you'll need another hard drive or external storage)
Macrium Reflect creates an accurate and reliable Image of a hard disk or the partitions on the disk. In the event of a partial or complete system loss, you can use this image to restore the entire disk, one or more partitions, or even individual files and folders.
During the imaging process, Macrium Reflect copies the contents of entire volumes including a reference to their physical location on the storage device to an image file (.mrimg). You would normally store the image file on local or network drives, or removable drives connected using USB or eSATA.
We strongly recommend that you create an image of your system at regular intervals.
BinaryMode
Banned
2600 dialtone blvd
Read and learn how to use Ventoy. Then place the ISO of Clonezilla on a Ventoy formatted USB drive.
With Clonezilla you can make an image of the drive or clone the whole thing to another drive of equal or greater size. Clonezilla WILL clone encrypted drives. Use the commands, J2, Q1, Rescue. That's what I use. If you chose encryption FDE (Full Disk Encryption) cloning the drive can help with data analysis... With software like Truecrypt or Veracrypt one needs to absolutely read the ENTIRE manual.
Anyway, that's my nerding out for the day. I highly doubt most even know or use what I do. But figured if someone came along here they may find the information useful.
All my backups are in four fireproof safes. Then I utilize cloud storage but the data is encrypted by ME first before it's sent to someone's server. I use AWS S3, BunnyCDN and Mega.
arlo
Thanks to everyone for the information!
