I'm sorry but I don't know how to go back and retrieve that info.
Ed
If you are in the LCN Finder, then when you get ready to exit, you hit <FUNC>+<SYSTEM> to exit. You'll get a prompt to save what has been found. Select yes to save.
Past that, to see the LCN's found, the easiest way, of course, is to read the information from the scanner back into Sentinel or other software.
But, on the scanner itself, you can still get to it:
Press Menu
Scroll to Manage Favorites & select (press E-enter)
Scroll to the Favorites list that contains the system & press E
Select Review/Edit System & press E again
Scroll to the system & press E to select
Scroll to and select Edit Site
Scroll to and select the site name (if it is only one site, you'll see two choices, "New Site", and the actual named site in the scanner)
Note correction in Bold
Scroll to and select Set Frequencies
Scroll to the first frequency & press E to select
Scroll to Edit Frequency & select
At the Edit Frequency screen, just press "E" as you are not changing the entry
That will get you to the screen where you can either enter the LCN, or see what LCN Finder entered during the Analyze.
Just note what LCN number is shown, then press E to move on without changing it
Back at the list of Site Frequencies, scroll to the next frequency & repeat the above to see what was entered. If the LCN Finder did noot calculate an LCN for a given frequency, the value shown during the 'Frequency Edit' should be a zero.
Repeat the process above until you've gone through all of the frequencies for the site.
