Worcester PD Scanning
cadbob
Hi All, I have my WS1065 all Set for the Convental Scanning, but for the life of me can not get it to scan worcester City PD. I tried setting to P25 Auto, 800mhz, vhf/uhf, and LTR. I attached the PSREdit500 Bin File. I imported list from here and attached my Central Mass Channel List to this thread. Hope it is ok
  • Worc-County.zip
ecps92
Taxachusetts
Worcester [City of] is a P25 TRS and you are best to program it for trunking, keep in mind some of Worcesters TG's are Phase II and only can be heard with a Phase II scanner
cadbob
Yes I did , I think program it with Trunking, New to Scanner and All the Terms but reading and hopefully learning. :)
garys
Texas
From the screen shot you attached, it looks like you only programmed the control channels. It's been a while since I've had a Pro197/PSR600/WS 10, but as I recall it doesn't do Control Channel only trunking. Try programming in all of the channels and see if that works.
ecps92
Taxachusetts
Good Start, and the 1065 is the same as the 600, for programing, so the Control [All 4] channels are all you need.
But it will not do Phase II [only Phase I TGs]
Now the other issues is your Location [update your profile] Are you in/around aka Near Worcester [or too far away]
as the system is designed for Worcester coverage Only.
the other issue is experiment with your antenna, this is a simulcast system where all towers transmit at the same time.
sometimes smaller the antenna the better, or even moving an inch and one good trick was go with a paperclip
I do see you started a similar thread at ScanNew England...
cadbob
Hi Yes, I'm In Millbury so I dont think it would be 2 far for WPD?
Figured I would cross post as I downloaded list here, but actually has to do with our area which is on the other forum! LOL Reaching! LOL
ecps92
Taxachusetts
You should be good [update your RR profile, to indicate Millbury, it will help anyone else in the future]
Now as to how/what you are hearing, go into SEARCH mode and see how well you decode the Control Channel [hold on it]
You may need to do some adjusting of your antenna [YMMV]
garys
Texas
One other thing to consider. A friend of mine has a Pro 106 and has been trying to program it for he CoMIRS 700Mhz site in Boston. Like Worcester, it has a mix of Phase 1 and 2 TGs. He is having the same issue you are. He can't receive anything at all. He lives in Boston and signal strength is not an issue.
I don't know if there is some difference in the data stream between Phase 1 only systems and Phase 1/2 systems.
He has had no problem with the Cambridge or MassPort systems which are both Phase 1.
Maybe for some reason the GRE/RS/Whistler scanners aren't capable of decoding the data stream.
cadbob
I might try messing with the settings I circled here "Off" dont seem to work so that leaves "ROAM" and "STAT"
I guess P25 Auto is the setting I want for WPD?
Nascar18
Southeast Massachusetts
I would put the CC 1. 858.1375 & 2, 857.2625 in the list. Then turn Multi Site Mode: ON and then chose STAT and Check All CC: Yes. Another thing I would lock out the Wildcard!!
cadbob
Thank you Trying it now, not sure how to lock out wild card thou?
ecps92
Taxachusetts
my [GRE600 and [RS Pro652] work fine on the CoMIRS 700 , once the antenna was properly aligned to handle the simulcast issues, the only TG's I would/do not get are the Phase II
I'm going for [right now] he is having the simulcast issues and needs to adjust [decrease his antenna]
Nascar18
Just put the Control Channels 1 & 2 in the frequency list, not all of the system frequencies. I would also put 2 in the CC Dwell box. Learn to use the scanner you can LOCK OUT the Wildcard that way!
garys
Texas
That's a good thought. He never mentioned what he was using for an antenna. I'll mention it to him. I never had any problems with my 536, so I've never given it that much consideration.
cadbob
I Opened the Box for my WS1065 Christmas Day, up until 12-25, never knew a lick about scanners other than seeing the old crystal type scanners in peoples houses, still learning all the terms and radio jargon. :) lol
Nascar18
Garys,
I would suggest adding the Dwell to 20 on his Pro 106 for that system. I find if I don't have my dwell at 20 for the RISCON East I don't receive the system the same. I find the P-25 systems use the dwell time better.
garys
Texas
I'm also going to suggest that he try turning on the attenuator. When we had PSR600 scanners in the ambulances, I had to turn on attenuation for the MSP 800 analog system because it became overloaded in areas close to where he lives.
