Wouxun 5.00K to 2.500K
dksac2
Idaho
Is it possible to change the radios (KG-UV6D) with the 5.00 step to the 2.50 step using the software or is that something built into the radio?
Thanks, John
nd5y
Wichita Falls, TX
From what I have read only certain firmware versions have 2.5 kHz synthesizer steps and you can't add it to a version that doesn't have it.
2.5 kHz steps are required for programming most of the 7.5 kHz splinter VHF channels used in the US.
D
DaveNF2G
Guest
Then what you need is a 7.5 kHz step size to comply with the bandplan, right? If the radio has 15 kHz step sizes already, then cutting that in half seems like a relatively simple software (or maybe firmware) update.
nd5y
Wichita Falls, TX
No. VHF radios need 2.5 kHz synthesizer steps. Most of the FCC allocated channels in the 150-162 MHz band are spaced 7.5 kHz from eachother but not in 7.5 kHz steps continuously from one end of the band to the other.
nd5y
Wichita Falls, TX
If you set the a radio to 6.25 or 12.25 kHz steps then a few of the 7.5 kHz channels like 151.1375 will fall on multiples of 6.25.
