wouxun kg 950p radio
wildbill0013
my wife gave me one of these radios for christmas. after programing the radio with 10 frequencies i tryed to scan the ten freqs and all it scans is 4 of the ten that are programed. to see if they all loaded correctly i reconnected thecable and after reading from radio it shows all ten frequencys in memory.
any suggestions??????????????????????????
nd5y
Wichita Falls, TX
I haven't seen the the programming software for that radio but I assume it is similar to the software for their hand helds.
It should have an entry for each channel to scan or skip the channel.
Make sure all the channels you want to scan are enabled.
WB4CS
Northern Alabama
Another thing to try...
What frequencies do you have programmed into the radio that won't scan? Are they frequencies that the radio is capable of receiving?
CaptDan
Ocala, Florida
Another thing - if it's like the 920, besides being able to program each channel to scan or not, there are "blocks" of channels in the radio than can be set to scan as a block, or the entire radio. If the 10 frequencies are entered into channels 1 thru 10 then this should not be the issue.
wildbill0013
hey capt dan, i thought the same thing as far as the scan blocks, when i go the the section on setting scan blocks i highlighted "all" but it still seems to only scan 4 out of the 10 that are in memory. i then tryed to try scanning just block "1" which is channels 1-99 but still only scanning 4 out of ten.
i am stumped?
wildbill0013
kg-uv950p
just to keep everyone in the loop it seems to be a software problem with this radio. i spoke with the mfg and they are in the process of trying to figure out why it wont scan if you program it by software but yet will scan if you enter them manually. with the radio having 999 channels of memory i dont see programming that many channels into the radio by hand so i think i will just wait to see when they come out with a patch.
lerymup
Aurora. IL
Known Wouxun UV-950p Issue
I have the same programming issue. Its been out there in complaints for the past 2 months anyway. Dealer says they are "working" on it. I am going to eat the restock charge to get it out of my sight. Lesson learned.
robertmac
I do not see the answer to the question about what programmed frequencies are not showing up when scanning. Wonder if they are outside band the radio covers?
wildbill0013
coverage?
all the frequencies that are programmed into the radio are within specs to include offsets and pl tones. the problem is in the software, we spoke to the dealer and he tried the same frequencies on multiple radios in his shop and they are doing the same thing. i have them programmed into the radio manually and they scan fine. the problem is not he radio.i would not give up on this rig it is a soild radio if you are willing to overlook the software issue.
wildbill0013
just to keep everyone in the loop i want to let everyone know that the new software works perfectly i can now scan all channels programed into the radio using the software
