Wouxun KG-UVD1P Issue
glockasp
Boston
Hello guys.
Got a problem with a Wouxun that I'm just not sure about.
I have a pair of KG-UVD1P's, They are both J03's and are IMHO great little radios.
I wanted to have extended receive on the units (a lot of out local PD and FD's are on T-Band). They only went up to 480.000 by default, and I needed T-Band, just receive though no TX (just don't need it). So i went ahead and used the band expander program 1KG-xxx-unlock. It works great opened her right up. I did not open up the TX past what it already had just the RX up to 512.0000.
After flashing the radios with the MURS freq's and one T-Band receive freq. I found both units would reset all of the optional functions menu items after powering off the unit. It would go back to talking Chinese to me (lol). I reflashed both radios and one works fine and the other, well it still does it. Have any of you seen, had or even heard of this problem before????
I am using the Wouxun software V2.11, a USB to serial programing cable and an XP box.
ipfd320
Banned
W.Babylon N.Y. 11704
did you try the menu manually on the keyboard to set the radio to english?????
if not try that and turn the radio off wait a few then back on
good luck
pjtnascar
Sussex County, NJ
My TYT will do the same thing every time I program freqs with the computer. You should be able to reset those functions through the radio menu.
glockasp
Boston
It's weird, I can tell when the unit it is going to do it to. The power on will not show the second line of the VFO and then it tells me in Chinese that in is in frequency mode, when it should be in English and name mode.
It also only seem to happen if the unit is turned off and then back on again. It also happened if I took the battery off too. The channels are there and programed it just the optional functions that reset. Sometimes the display will not come on either, I have to turn the unit on and off again to get the display to come back on.
But the unit still works and other then this little hiccup it's a great little radio.
I'm to tired to do it now, but sometime tomorrow I'm going to try some of the older versions of the software and see if that makes a difference. and I might give the commander & CHIRP software a shot too if the older versions don't fix up the issue. I'm thinking trial and error till either i get it or it gets me.
ipfd320
Banned
DO Your Functions MANUALLY Thru the KEYPAD....Dont use the PC to do it for YOU
Go thru EVERY Item in the MENU Choices and Manually Enter them IN
nd5y
Wichita Falls, TX
I read on one of the other forums that you can't do that. It said If you try to expand the default receive range from what is on the label (they way it was manufactured) it can ruin the radio and the unlock software is only to change the trasmit range from ham band only.
