Wouxun Wouxun KG-UVD1P
Jimboh66
Hello all
Have above mentioned radio and having difficulty getting speaker Mike's to work, I plug one in still hear through radio speaker, have purchased compatible units but non have functioned, any/all help appreciated
Jim
ladn
While it might be a lower than usual CCR quality control issue, this problem could also be caused by the speaker/mic plug not fully seating in the radio body connector.
Look VERY CAREFULLY at how the connector seats (especially the back end of the connecter where the cable comes in). The connector needs to sit flush with the top surface of the radio body socket. If it's not, you may need to carefully remove a small amount of plastic from the speaker/mic plug.
ladn
Have tried 3 different models of speaker mike's, all the same results
But did you do as suggested and carefully examine the fit of the speaker/mic plug to the surface of the radio socket?
I you have an appropriate set of connectors, you could test the radio side socket a 2.5mm plug adapted to whatever earphone you happen to have.
