Wouxun UVD1P and UV3D
LtDoc
Oklahoma
There may be a confusion in terminology. Both can send 'PL' tones commonly used to access repeaters. I don't have a need for sending 'DTMF' tones so haven't checked that. I do know those 'DTMF' tones can be used with phone connections to 'dial' a number, and some radios store those tones to make things more 'automatic'.
That help any?
- 'Doc
nd5y
Wichita Falls, TX
I was told these radios can transmit an automatic DTMF signal over the air. How do you set this up? Is this even possible? Hope you all can help,
You have to use the ANI settings in the programming software.
You can't do it from the keypad.
You can program up to 6 digits and it sends them all the time on all channels. It is a global setting.
squirrel911
Estill Springs/Decherd/Winchester/Franklin County
they can, as with most ham gear. why would you need to transmit dtmf around here though?
I was told our rescue squad uses DTMF for the ID system on the radio system
That help any?
- 'Doc
No i knew that already. Thank you though
oh ok thank you
scma127
Fontana California
wouxon radio 2mtr/440 and 2mtr/220 radios
are thes good radios inned a new hanheld radio found them on sale for 119.00 does anyone?
newsphotog
Des Moines, IA
For what they cost, the general consensus is that they are pretty decent radios... but be prepared to be frustrated when reading the manual.
