Howdy,
Years ago my dad had a portable SW radio that would pickup the WWV time signal in Ft. Collins, CO. I believe we used to get it around 10 MHz here in NY. Now that I have gotten back into clocks and clock repair, the 'beat' that is on there is a good thing to use to set clocks in beat. Used to use it a couple times when I was a kid to do it. So what would you all recommend to try to get the signa; in central NY without a) breaking the bank and b) having to use an outside antenna. I do have a RTL stick that is on an outdoor antenna but haven't tried to see if I could get the signal with it as right now it is used for the NOAA radio I provide online.
Jeff
Jeff
