Wyoming state wildland fire channels
PJH
Does anyone have an accurate list of the state used wildland channels? I have one from 2 or 4 years ago, and I am willing to make a new category, but not sure if they change as often as some of the Federal ones to make it worthwhile...
Any of the frequencies should be good still. The AG channels and all the Cad base stuff is still good.
The only thing that changes from year to year are the PL tones associated with a repeater. Forest Service is the worst. It changes so much, most of the FS workers don't even know what they new ones are. That is why the BK stuff is so popular, you can make changes on the fly.
That said, at least the frequencies stay the same.
PJH
I should have the state channels up later tonight... if anyone recognizes they layout/format and can submit corrections that would be great.
I am still working on clarifications but at least its a starting point.
PJH
Guys, take a look at this: State Foresty Scanner Frequencies and Radio Frequency Reference
Some quick FCC searching shows a couple of the channels are licensed back into WyoLink and Montanna Dept of Emergency Services.
If anyone knows/has access to current information I'll update/delete the above list as needed. I do know these were in use in the northwest corner of the state (Yellowstone area) and from my source it is believed to be statewide - but again the information may be a little dated.
mtnfireguy
NE Wyoming
That appears to be the Montana Mutual Aid Frequency Chart.
Wyoming does not use colors for channels and only uses a few of those listed
PJH
Do you have a list of those in use in Wyoming and designations?
The list came out of the Yellowstone area as Wyoming channels, with Montana involvement so in a way I figured it was more of a Montana thing.
PJH
Sounds good. Shoot me a PM when you do and I'll make the necessary changes.
Should I just kill the entry for now? Seems like a new fresh start would be easy.
tyytor
Wyoming
hi, i have scoured the fcc db for wyoming and i could only find these for state wildland fire channels
151.1375 VTAC 11
151.1600 St. Forestry
151.2950 St. Forestry
151.4300 St. Forestry
154.2800 Fern
154.4525 VTAC 12
155.7525 VCALL 10
157.2500 VTAC17 TX
158.7375 VTAC 38 RX
159.4725 VTAC 38 TX
161.8500 VTAC17 RX
170.5750 A/G?
there my be more as i am not in the know and was to far away from the fires last year.
tyytor
Wyoming
and of course these in the database
19390 4bbe D Forestry Forestry - statewide Fire-Talk
19396 4bc4 D Forest Heli Forestry - Helitack (Helitrunk)
Halfpint
Slightly NE of the People's Republic of Firestone
Getting an early start and reviving this...
But does anyone have current freq's still for this, or should I just nuke this category for now (as these seem to be the Montana channels)?
I think that this line pretty much says it, "These frequencies are known to be used for State Wildland Fire Incidents and also may be shared with resources in Montanna." and *if* there are any major changes that need to be actually done it would be better done at the beginning of next year's fire `season' rather than doing something to be doing something?
PJH
Not really. That was the line given to the rrdb on the assumption they were Wyoming channels, but they really are part of, or are the Montanna channel plan - not wyomings. Hence the clairlification needed.
