x36 recording data fields
troymail
Silent Key
Anyone have a pointer to how to find information in the recording headers? Specifically, I'm looking for the system "site" string in the recordings.
The entire listing of what is supposed (less the bugs) to be captured in the headers would be great....
theaton
Member N7VU
Moab, Utah
WAV file header
I did some searching and found a simple routine to extract the WAV file header. Here is the VBA code in Excel. If you type the full path/filename in the upper left cell and double-click any cell the header will pop up in a window. I'm very pleased that the tone is recorded in the header for conventional listings. I plan to write a routine that will rename the files to include the freq/tone or system/TG and sort them into a more useful file structure. -Tim
Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
Cancel = True
Dim i%, str$, Chunk(900) As Byte
f = FreeFile
Open Cells(1, 1) For Binary Access Read As f
Get f, , Chunk()
Close f
Do
If Chunk(i) > 31 And Chunk(i) < 127 Then str = str & Chr(Chunk(i))
i = i + 1
Loop Until i = 900
MsgBox str
End Sub
Here is the header from a trunked recording:
RIFFMWAVELIST4INFOIART@South Dakota State Radio Systeme
/ Natl Interagency Fire Ctr -IGNR@Yankton Countylk Point
Center - Ground Ops - LogisticsINAM@Sheriff 1rationsticalcalgers6352p'sty)ICMT@GID:321601IPRDBCDx36HPIKEYn!ICRD20140203100534ISRC88.5ITCH@ISBJ@Full
DatabaseICOP****************unidFull Database00001.hpdOnOn11OffOffOffOffOffOffOffOfSouth
Dakota State Radio SystemOffMotorolaAreYankton CountyOff43.000000-97.40000020.0CircleTGIDTid=2Sheriff
1Off18624DIGITAL2TGIDTid=118820TGroupId=VermillionOff42.795830-96.90972025.0NFMCus
And from a conventional recording:
RIFFhqWAVELIST4INFOIART@Clay Dakota State Radio Systeme
/ Natl Interagency Fire Ctr -IGNR@Clay Countytylk Point
Center - Ground Ops - LogisticsINAM@Vermillion Fire/EMS
Tacticalgers6352p'sty)ICMT@GID:321601IPRDBCDx36HPIKEYICRD20140203100739ISRCC88.5ITCH@ISBJ@Full
DatabaseICOP****************unidFull Database00001.hpdOnOn11OffOffOffOffOffOffOffOfClayOffConventionalAreaStateCountyId=2372StateId=Clay
CountyOff42.916661-96.95865725.0CircleC-FreqCFreqIVermillion
Fire/EMS TacticalOff154815000FMTONE=C88.58TPddH
Dewey
I forget where I found this. It pertains to the HP-1, but also appears to apply to the x36. The only "problem" is that the x36 ends some of the metadata tags with hex x10h instead of the standard x40h. I don't recall which ones are affected, but you can find them looking at my previous posts or search meta (I just posted in day before yesterday).
