XG-100M 7/800 mhz no transmit
myimpala1
NJ
I have a xg-100m and when i use the putty commands i get no output on the 7/800
. The receive on this radio is poor on 7/800. I checked the solder joint from a previous post and found no issue there. Has anyone seen this or does anyone have a fix for this? thanks.
myimpala1
NJ
i also have a bricked xg-100m. could the parts be swapped from that to make this operational?
merlin
DN32su
The antenna switching ICs can fail if the antenna is hit by lightning, even indirectly. A very strong RF field can also damage it.
For starters, you need sevice manuals which there are none for th XG-100M. The XG-75 is as close as you will find.
You need very good skills with SMT and eqipment for that.
You might be ahead of the game swapping out the entire RF board, of course, it is the innermost board in the brick.
I may be able to help with that. PM sent.
