XG-100M No Audio Trunked
AF1UD
I recently acquired another xg-100m. However the audio works fine while hooked up to my sp-721 except for when I have a trucked system selected. I believe the radio has old firmware but I updated the burn and boot app to the latest...
Any help would be appreciated.
Thanks!
lbd1123
Could be a blown speaker, have you tried to connect a speaker mic to the radio ?
AF1UD
The speaker works fine except when listening to trucked p25p2 systems. Analog is all good.
lbd1123
Ahh does the radio say CC Scan?? Do you have the Trunking feature in your radio
AF1UD
All trunking features enabled and it starts off by showing CC scan and then it goes away.
It's the programming file I use on all of my XG-100Ms.
Forts
Ontario, Canada
You mentioned you updated the burnapp and bootapp... Have you also done the actual firmware and MCU? Possibly control head FW too...
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Check the channel plan. If it's not exactly right you won't hear anything.
