XG-100p issue
lucas12139
Does anyone know what could be causing my xg100p to connect to a p25 using nas but not pickup any talk groups radio is showing the blue bars completely filled I can hear perfectly fine on my unication g5 but not the radio. Any help would be appreciated.
BMDaug
I am licensed…
Central Colorado, USA
Make sure your group set lists all of the TGs you want to hear. When setting that up, don’t forget to uncheck the CALL and TX boxes for each TG.
kg4ojj
Crisp County, GA, USA
Double-check everything on the TRS settings - for example, the Unication does not require the correct NAC for each site.
nikronzo
4.X SloppyCast
I thought you had your local shop program it professionally??
lucas12139
Yeah was supposed to be but I guess $100 later I bit the dust on that one
lucas12139
would the TDMA check box have to do with the radio not receiving from the talkgroups?
natedawg1604
Colorado
First thing to check is the band plan, that's the most common error.
Also make sure you didn't check the scan box on more than 127 talkgroups. There is a longstanding undocumented bug in RPM, in which the radio will never unmute if you try to scan more than 127 TGs in one group set.
