XG-100P Receive mixed mode, transmit analog.
KG5HHS
D/FW
Hello All,
I recently got a XG-100P. I'm very new to this radio. I have been able to play around with it and figure most things out. I know the radio can receive both P25 and Analog conventional while transmitting in P25, but is there a way to Receive both P25 and Analog while transmitting in analog? When I got to change the transmit mode to analog, the P25 options gray out.
tweiss3
Is it time for Coffee?
Ohio
You build the system as a P25 conventional, but the channel is analog. Set the correct RX NAC
KG5HHS
D/FW
Okay, just to clarify, the RX NAC is to be set before it is grayed out by select analog?
tweiss3
Ohio
I think that's correct. It has been a while since I verified this on the bench.
BMDaug
I am licensed…
Central Colorado, USA
So can you scan analog/conventional channels along with a trunking channel at the same time ?
Technically yes, it’s called a custom scan list. In practice, you need to have very few conventional channels in that list of you want to hear stuff… keep it to under half a dozen and you’ll get mostly ‘acceptable’ results.
-B
-B
Great, Thank you Sir..
Forts
Ontario, Canada
You can scan conventional channels from a trunked system, but not vice versa. Also on mixed mode receive I'm reasonably sure you can only tx in P25. Been a while since I looked at it though...
