Xg-100p scanning trunking.
AES-256-Encryption
Based in the US, always nationwide
ØAES
I have a few xg100's. Ive programmed trunking on other harris radios and understand procedures. My question is, does disabling gps in the rpm make the system not receive gps data? Thats all I wanna know. With the xl you have to data inhibit. Thanks
mpcpsrego1
Nebraska
Yes if you uncheck the GPS box in RPM it will disable GPS logging on the radio side. It's the same as unchecking the bluetooth box in RPM the radio will show it disabled. Hope that helps any!
AES-256-Encryption
ØAES
Well for example, NAS or whatever RX only, can GPS be enabled or does it send GPS data to the CC?
mpcpsrego1
Nebraska
No it doesnt send any affiliation packets, I have GPS enabled on all my XG100p's that have that feature with non registration trunking programmed on all of them and not one packet is sent. You just have to make sure your programming is done right in the system and groups to not send packets. The GPS in Harris is more like the GPS in your car just gives you your lat/long, altitude etc info and current satellite teathering and thats all for that specific radio. Now if you combine a bunch of 100's with in band GPS and have them connected on a system then you'll be able to see radios within a geographical area to you but they have to be linked. Kinda like radar, thats the 3rd screen in the GPS view folder, looks like a bullseye with a green dot in the center. Anyhow hope that helps any.
