xg100p program cable
Reconrider
Inside the Galaxy
Radio Galaxy
I’d save the headache and cough up the dough… but that’s just me… also the fear of bricking a $1000+ piece of discontinued equipment gives me nightmares
I did end up buying one a few days ago. Just waiting for it to get here.
Is it hard to make the cables? I like building things, breaking the radio doesn't bother me. I rarely use it as it is, just wanted a project to make me get to using it again
wa8pyr
Staff member
Lead Database Admin
Ohio
Would you say it's better to make the xg-100p update cable, or better to buy it?
Depends on how confident you are in your construction skills. That diagram posted in an earlier message gives all the details needed to build a usb programming cable so I’m going to do it.
Reconrider
Inside the Galaxy
Radio Galaxy
So I got the cable, but can't figure out why it's not being seen by the computer.
Plugged it in and I don't get a com port or "unknown" or "installing...".
Do you have any idea what might be needed for it to work?
TDR-94
You have to have the XG-100P connected and turned on before the computer will recognize the cable and the radio is connected.
Reconrider
Inside the Galaxy
Radio Galaxy
I have the radio connected and then I plug it in. Nothing happens, or at least nothing that I see. RPM doesn't let me read/write via usb.
Might be you missing the drivers...Look under program Files and you should see Harris radio usb drivers
I have the folder there with the following files - https://prnt.sc/20y0l6j
TDR-94
The USB driver should automatically install when installing RPM.
TDR-94
You can confirm the Harris USB driver files are loaded by looking in your C: drive under Program Files and Harris Radio USB Driver.
There was a batch of cables that were bad.
Reconrider
Inside the Galaxy
Radio Galaxy
I have the files there, or at least what files RPM unpacked when I installed the program. You can see the files https://prnt.sc/20y0l6j
TDR-94
It should be in the folder with the RPM files, in the Harris Radio USB Driver folder. Make sure to use the correct file for your operating system
TDR-94
Not the folder on your C: drive. The folder of RPM files that you used to install RPM.
TDR-94
Just to confirm, you are using the Unity Product Management tab, in RPM, to program the radio, correct?
Reconrider
Inside the Galaxy
Radio Galaxy
I ended up have an operator error lol.
Figured out I wasn't clipping it INSIDE the top before screwing it in
