XPR XPR 4550 Programming issues
Mtnrider
Greene County New Yawk
I have 2 XPR 4550's .....One i programmed with a older version and one i tried to. got the dreaded "wrong" outdated upon trying second radio
i then downloaded the latest greatest from Mother M....2.157.149.0 a no go...Ideas ? I'm out of them....
K9KLC
Southwest, IL
Get 16.828 from Motorola's site then you should be good to go. Also make sure the 4550's are updated to the last publicly available firmware 1.12.17. I do use a version of 2.0 to program my 4550s but it's an older version of 2.0 and I have no plans to update that version.
All updates to the 4550's have to happen on CPS 16 as far as I know.
K9KLC
Southwest, IL
Older CPS worked . Thanks
Glad you got it going, if you get the 1.12.17 firmware at least with some versions of 2.0. you can program those. Caveat is, if you need wide band for ham radio you'll have to actually buy that from /\/\. For CPS 16 some googling will get you the Wideband stuff. Not sure how you're using the radios.
