- Joined
- Dec 1, 2006
- Messages
- 686
- Reaction score
- 163
Hi, I have a Mototurbo XPR 5550 in my work truck. If the truck sits for 4 or 5 days the battery is dead. If I pull the fuse on the radio and let it sit, the battery isn't dead. I know quite a few other work trucks with Motorola radios have this same issue. So a power cutoff was installed in the main power line off the battery. When the key is **** off, the relay opens and drops power to the radio on the content power line from the battery. The smaller wire for the ignition is on the same relay now. My problem is, when I start the truck, the Moto radio doesn't power up on it's own, I have to turn the power on with the button. (and I forget all the time) I also have a Kenwood radio on the same relay and it goes on with no issues. I looked in the CPU and didn't see an option to change to let it power up when power is restored to the unit. Any ideas how to do this through the CPU or any other way to get it to go on with the ignition and not kill my battery all the time? Thanks
