Icom: IC-718 Main unit Problem.
piqahm99
Hallo
Here I have problem with main unit of icom 718. when i install main unit to icom 718. it cannot power on. But if I swap with another main unit it can open it. so i expect the main unit problem because cannot power on. can anyone help me . how to detect why that main unit related with power on the icom 718. Becaus i check the component is going well.
Thank you.
AK9R
Staff member
Super Moderator
Central Indiana
Icom IC-718 main unit? The IC-718 is a monolithic radio. There is no separate main unit as far as I know.
piqahm99
its separate main unit pcb. thats why i want someone to help me about this. cause i check all the component is good..but no power if use this main unit .
W4AXW
A Keeper of the 6m SSB Flame
Main unit??= Power supply??
piqahm99
No. that icom 718 have power board. but power board just okay if using another main unit. but if i using that main unit problem it cannot working. thats weird.
sloop
Lewisville, NC
I don't mean to be rude, but are you a ham or a CBer trying to use the 718 as a CB?
The 718 uses an outboard (separate) power supply.
The last time I looked at my 718 there was only one main board.
When you use "main unit" please tell us the function of this item.
Sorry but your post is filled with too many ambiguities for anyone to help. We need specifics.
AK9R
Staff member
Super Moderator
Central Indiana
The IC-718 has six circuit boards which Icom names: Main Unit, PLL Unit, PA Unit, Filter Unit, Logic Unit, and Front Unit.
piqahm99
Like this.. I am technician to repair the icom 718. So i have many mainboard as spare part. so i change the mainboard to try and error.. so when i try one by one to diagnose.. so i get that main board make the 718 not work. when i try another main board with the same power board. the 718 function. so thats why i need anyone to help me. cause i check all the component of the mainboard is good. is it clear sir?
piqahm99
yes this is i know. cause i already refer to manual service pdf.
