XPR XPR 6550 O.O.B. Mod Question
N1SQB
Somewhere On Earth
I finally got my XPR6550 ( 403-470Mhz. ) I was initially told that it was programmed with R16 version CPS. Turns out it was programmed with R13 CPS and my R14 will work. I programmed the radio exactly how I wanted it with no issues. I saved the codeplug and I am working off of a separate codeplug I created for testing purposes. I downloaded HxD as the OOB mod asks you to. Unfortunately, I have not been able to successfully change the upper limits. I want to go from 470 to 480 to allow programming of some local channels just past 470. Every time I get to th point of hitting "replace all" to replace 470.000000 with 480.000000 it says it cannot find 470.000000. I tried it with 3 zeros and 6 zeros after the decimal with no luck. Can anyone suggest anything else? I am running windows 10 and HxD is running with admin. privileges.
Manny
hakwye8518
Town of Islip, NY
open cps. read the radio and save the codeplug. then open hxd and open ram select mototrbocps. then click search and click replace. type in 470.000000 and 480.000000 click the box that says unicode string then click replace all save it and go back to your still open codeplug in cps navigate away from the radio info screen and back to it and it should say frequency range 403.000000-480.000000
hakwye8518
Town of Islip, NY
Does it not look like this when you click search and then replace
N1SQB
Somewhere On Earth
No it does not and that turned out to be the problem. The latest version of HxD has a different screen. If you don't look carefully you won't realize that you have to touch the down arrow and reveal the unicode option. Once I realized the issue, I had no problem with the modification
tunnelmot
Conroe, TX
I had to try a couple times before it would "take"> IIRC, i think I pushed mine well into the T-Band with no probs.
N1SQB
Somewhere On Earth
I only needed it to go to 480 to monitor local departments. However, if I’m going to do the mod, might as well go all the way....I won’t be TX-ing up that high anyway, just RX-ing so I’m good. I can hear some of the L.I.and NYC stuff in the 482.XXX
ranges.
Manny
