XPR 7550 programming issue
Hi, I recently purchased a xpr 7550 and when I go to program it in cps software it says the code plug version is not supported. Look in help files for supported versions. I tired looking in the help files and couldn't find anything about it. I'm very new to using Motorola radios and don't know a lot about them. Any help would be great thanks.
CPS Version 2.146.122.0
Firmware Version R02.30.21
CP Version 06.03.10
Firebuff880
Boynton Beach, FL
You have a subscriber that has not been touched since 2014. Firmware Version R02.30.21 AKA R2.03.21 (Motorola's Abacus was broken for a while back then). To get this to R2.10.05 The most current release you can before paying for a SUM entitlement you need old firmware packages and CPS to walk it forward.
Based on your post return it to whoever sold it to you, You were ripped off.
Thank you for the help I really appreciate it, I was able to program it with CPS R16.0 Build 828. Unfortunately I bought it on eBay from a seller that doesn't do returns so i think I'm out of luck as far as returning it goes. Now that I can program the radio is it a tedious process to walk it forward so i can use it with the latest CPS or am i better off leaving it how it is. I'm using it for receiving only not transmitting.
tweiss3
Is it time for Coffee?
Ohio
For ham, there is no benefit to CPS2.0.
