XPR-8400 UHF Repeater
billb52
Urbanna, Va
Need help with a repeater, I have a XPR8400 (uhf) that was working fine, programing was done with CPS16. Since I update the firmware to R02.07.00.04, I can read/write using CPS 2.0 like normal, But repeater will not transmit or receive and I am unable to read it with RDAC and cps16 anymore. I tried digital and analog cannels but no repeater operation. I also replaced the memory battery. I apricate any help.
Firebuff880
Boynton Beach, FL
Since you are already using CPS 2 with this unit, update it to R2.10.0x from myView and then try again.
Be sure that RAS among other options is set properly. In both the Repeaters and the subscribers you are testing with.
Jeff
billb52
Urbanna, Va
Hey Thanks Jeff, I downloaded 2.10 from MyView, But when I try to update it. The "update status" green bar tries to read it but goes into timeout and indicates "fail to update device, please contact customer serv" I tried a "restore" and get same thing! Weird, like I said I can read and write with CPS2.0 just fine..
Firebuff880
Boynton Beach, FL
Sorry. No clue -
Nextgentow88
New york
From my experience so far no read and write could be programming cable control board shot i just replaced mine i had the same problem no read or write at all. Also the flat ribbon cables sometimes give up clean them but be delicate because they arent to tough
