XPR XPR I need help with reading a XPR 3300e
kj1080
Purchased a used radio and when i try to clone it cps 2.0 saying it password protected. what my quickest way around this?
kb9klc
Define try to "clone it" the subject said you're trying to read it. What exactly are you trying to do read it or clone another plug to it ?
aaronhoff
that only works if he has the same firmware loaded on his computer
You can recover to whatever firmware you'd like. As long as the software update license is still valid on the device. If not, you'll be stuck to any firmware 2.10 or older.
FFPM571
Nashvillle
But if he cant read it he wont know what verison of firmware it has to recover it.. If its too new or too old it wont work... and If its over 5 years old the software update is probably expired
Firebuff880
Boynton Beach, FL
any thing else i can do?
NO not really, since it's a non-display subscriber there's no way other than reading it to know what firmware is in it, and to do a Device Recover you have to use the same version of Firmware. So you can guess starting with the Firmware Version that the Subscriber was released with and integrate from there till you find it, or as suggested return it.
MN006055A01-AM Chapter 1: Introduction to Customer Programming Software (CPS) 2.0
CPS 2.0 Device Menu -> Recover
Allows the user to revive a failed radio due to data corruption by rewriting a good firmware into the radio. The CPS 2.0 preserves the tuning block of the radio before recovery is initiated. See Recovering Radios on page 70.
Radio recovery allows the user to refresh the radio by writing the firmware files to the device along with the default codeplug. The user can use Recover to revive a failed radio because of data corruption or get the radio back to a default "out of box" state. Unlike Update, Recover allows the user to rewrite the same version of firmware that is already deployed in the target device. During the Recover operation, the Customer Programming Software (CPS) 2.0 preserves the tuning block of the radio before recovery is initiated but all user programmable fields are reset to their default values.
kj1080
Who on here can do a 1 on 1 training with me remoted in my computer and help me learn this. I will pay
