XPR MDC-1200 display timer....
APX8000
Sarcastic Member
AES-256 secured
I've looked all over CPS 16 and 2.0 and I can't seem to find a setting for a timer with MDC-1200. When I have MDC enabled on RX to DOS mute the ear bleed squuuuaaaakkkk, the radio will display the MDC ID just fine and mute it to its nice little birdie chirp....the problem is that the ID will remain on the screen until the carrier drops or another TX with another ID replaces it, and then that remains. Is there a way to set a timer so it displays the ID and then converts back to the channel name in a set time ?
Mind you I'm coming from APX gear which displays the ID on the 3rd line so excuse my newbie post if its something like "turn on expert view" lol
Hectomilan
California
maybe I can help. I will get back to you in a few minutes i have to open my computer !
Hectomilan
California
So if you click on the MDC file you get all the options for signaling. And you can see the times I’m not sure what they all mean but if this helps in any way their it is sir.
