XPR3500e programming features
arlo
I am programming a new XPR3500e for analog. Can menu button be unprogrammed or can utilities program options be very limited. A user does not need so many ways to mess up radio.
Ant9270
The Green Weenie
You can uncheck whatever you don’t want to be accessed in the menu option. You can make them fool proof, very easily.
arlo
That is what I thought. The only thing checked is edit scan list. I can see and change all utilities.
ts548
Make sure to disable the FPP in the general settings. Usually its set to user, set it to disabled. That should kill most in the utilities menu from the radio.
N1GTL
CT
I don't see this option. I only see "Front Programming Password". I've never changed it from user and I would think it only prevents a user from putting a password in?
arlo
Setting front programming password mode to disabled is what I needed.
arlo
ts548
You change that setting if you don't want users screwing around in the utilities menu. Motorola really should call it something different, don't know why they decided to call it that.
N1GTL
CT
Well, I learned something new. I've always tried unchecking all the menu boxes but could never get rid of everything. I'd agree....incorrectly named but I'll use it now.
