XPR4550 old software safe?
kb5udf
Louisiana
Hi Gang,
I have a friend who is retired from the 2-way business. He has an XPR4550 and he has his old (properly licensed) CPS laying about.
He does not know what CPS last programmed the radio. Is there any harm in trying the CPS he has, or will it risk bricking the radio
if the CPS is too old (like I have heard that will happen to MCS2000) series.
Bottom line, any harm in trying to write to radio with old software, or will it just throw an error and refuse to write like most Moto CPS?
a417
Does it read the radio?
The MCS2k were odd ducks (however for some reason I love mine) , and newer radio/cps versions are much more tolerant of "codeplug too new" or other issues. You're likely to get an error message than a boat-anchor.
kb5udf
Louisiana
He did not attempt to read yet; he bricked an MCS2k before so wanted clarification first.
a417
If he bricked an MCS2000 by trying to read it, it probably wasn't because of the software version mismatches.
There's a LONG time between the software written for those two mentioned radio lines, and it's much improved.
kb5udf
Louisiana
He did not brick the mcs2k trying to read it, it was a write.
Kayn, thanks for the answer.
K2NEC
5F6
He could have bricked it if something happened to the data while the radio was writing. It's happened to me before and with older radios like that, I'm not surprised it happened to him either. Doesn't necessarily have to be a software problem.
N4KVE
PALM BEACH, FLORIDA
I use CPS 13.5 to read/write to radios that were programmed in the past with 16.0. You can go back a bit, but not too much.
