xpr6550
hakwye8518
Town of Islip, NY
i have 2 xpr 6550s one 450-512 and one 403-470. the back light on the 450-512 radio is much nicer and the keypad also lights up. the back light on the 403-470 isn't as bright and the keypad doesn't light up. Is there a problem with the 403-470 radio, the seller i bought it from said it was new old stock.
PACNWDude
It could be the "new old stock" as backlights can become dim with age. It could also be a setting where a button was programmed for a dimmer feature. With CPS software you could read the radio and find out.
For models with partial or full keypads:
You can press the Menu button,then arrow left or right to Utilities. Select Radio Settings and arrow to Backlight. Then see what that is set to.
hakwye8518
Town of Islip, NY
after doing some more research i found that my 450-512 radio was made in may of 2010 and my 403-470 radio was made in march of 1994. I guess that's why the keypad doesn't light up and the screen back light is different. I was also wondering what the flat rate repair from Motorola costs as I'm having problems with the volume control on my 450-512 radio, and maybe depending on cost might send in the 403-470 radio to get the updated back-light and keypad back-light.
KG4INW
Midlothian, VA
1994 can't be right as those radios weren't introduced until 2007. Not sure on the cost but any authorized dealer should be able to help you.
hakwye8518
Town of Islip, NY
when i look up the radio this is what i get
Serial # : 037YUF2695
Model # : AAH55QDH9LA1AN
Warranty Status : Unit is not covered under warranty
Based On : Defaulted to One Year Warranty
Last Repair Date : --
Repair Warranty End : --
Manufactured Date : 31-MAR-1994
Manufacturer's Standard Warranty End : 30-MAR-1996
N4KVE
PALM BEACH, FLORIDA
That can not be a "U", because as others have said, that radio did not exist in 1994. And if the tag does say "U", it's a typo. Read the radio & see what the ser # really is.
KG4INW
Midlothian, VA
read from the radio serial # 037YUF2695 model # H55QDH9LA1AN
Well, it's not the first time I've seen a typo but I can tell you with all certainty, the 'U' should have been something else. Not sure what exactly but it's much newer than '94.
com501
The serial number does not exist in the Motorola database. Someone has hacked that radio. Probably explains the anomalies in the codeplug and why your backlight is different. Trbo radios are not hard to hack, and they aren't hard to screw up, as a consequence. Someone with not all the correct tools or knowledge can do a half job and get most of it right, but your dim display issue and your bogus serial number are two leading indicators of other issues. You might want to further inspect that radio.
hakwye8518
Town of Islip, NY
I'm not understanding, the sticker under the battery has the same model and serial number that come up when i read the radio so why does that mean the radio was hacked. what happens if the radio was hacked and i send it to Motorola for repair?
hakwye8518
Town of Islip, NY
Here's a photo of the label. A far as the screen is concerned the screen appears to be lit by 4 leds above the screen. radio on the left is the 450-512 radio on the right is the 403-470 notice the lack of keypad backlight and the picture doesn't do it justice on the screen backlight
hitechRadio
Was the U radio an Ebay purchase.
It had been known that the chinese are making exact replicas of motorola radio's. I have not seen an XPR replica, but I have seen a BPR40. It was very hard to tell the difference on the outside, until you opened it up to compare. Even the Motorola Labels on the fake were pretty dang close to the real deal. Even used Motorola Programing software just fine.
hakwye8518
Town of Islip, NY
yes it was purchased on eBay as new old stock. If I take the radio apart how do i tell if its a genuine Motorola radio. thanks everyone for the help with this.
hitechRadio
I could not tell you for sure on a XPR, never had one open.
In the BPR sloppy soldering, and ALT. parts inside. And overall fit and finish was poor or just different compared to the original.
Also the guy who purchased the BPR knew it was a hack, but was curious to see what the difference's where because it was so cheap. If he would have bought it not knowing it was a fake, I doubt he would of ever known.
I would open it up and see if the LED's for the keypad are populated. If they are populated, could be part of the problem with the dim display, not sure though. As I am pretty sure all XPR's had a lighted keypad.
As far as the S/N , I am scratching my head too!
hitechRadio
If your not happy with it, and don't think you got what you paid for. Open a case for return and get your money back.
