Hi all,
I have been looking at purchasing an NMN6274 to pair with my XPR7550, however I am finding conflicting information on what firmware the XPR needs to be for this mic to work with it, since Moto's site doesn't list the XPR7550 as compatible.
In my searching for an answer, I have come across clearly old eBay listings for an NMN6271, which state in the description that the minimum firmware required is R02.40.02 (or later) for the NMN6271 to function properly with the XPR7550 (I'm assuming it's the same for NMN6274).
My XPR7550 is currently on Firmware Version R02.09.00.0001 (has been on this version since I got it) & Codeplug Version 14.00.13
I am/ have been using CPS 16 Build 828 for programming it.
I do have a MOL account & can see & download firmware releases under MyView -> Entitlements -> Software, however none of them are R02.40.02.
I also found 2 threads in my searching, about basically the same topic.
One from 2017: (
forums.radioreference.com
One from 2022: (XPR 7550 pairing to a IMPRES XP RSM Mic)
The specific post I linked to in the 2017 one basically reiterates what I said above about firmware needing to be R02.40.02 (I am assuming the NMNN6261A in that post is a typo) & then the 2022 one references firmware 2.08 & 2.09, so I basically got 2 questions:
1. Would my current firmware (R02.09.00.0001) allow an NMN6274 to work with the XPR7550?
2. If not, would the most recent firmware release (on 3/15/2022) which is R02.21.01.1005, allow the NMN6274 to work properly with the XPR7550?
I am posting this, before purchasing an NMN6274 & updating the firmware on the XPR.
Hopefully this post was easy to understand.
Thanks in advance to anyone who can help.
One from 2017: (
Best dmr radio in 2017
Last year I got to looking into dmr and was looking at the cs 750 tyt md380 but money went short and that was about it for that idea. So now I'm back and ready to pull the trigger on my first dmr radio but my question is whats out there now that's better then these 2 radios but around or under...
