XPR7550 PTT question...
drdeputy
SW Missouri/Central Iowa/N Central FL
Thanks to a fellow across the pond for suggesting it, I have found that my PTT on the XPR7550 is going belly up. If you press -really- hard it will transmit and of course works normally with an accessory mic attached. Is there any cure for this? The same fellow says there is not without replacing the entire housing as the PPT membrane isn't a serviceable part. Is there agreement on that? Thanks.
K2NEC
NA
Correct, bad PTT means you need a new housing. Fortunately they're pretty cheap online since the 7550 is EOL
