XPR XPR7550e audio cuts out for half a second
alcahuete
Antelope Acres, California
Not sure that this is a MotoTRBO issue..... I don't have any such issue with any of mine, anywhere from 0 to 4 bars. Have 7550e radios and a mix of 5550e and 5550.
Floridarailfanning
East Tennessee
Must be nice. . .
Been having these issues regularly on numerous radios dating back MANY firmware versions. I started using the TRBO radios around either high R01 or right at R02 and it was going on at that time already.
For clarification, I only notice this with simplex. I don't recall ever having this happen on a repeater, except when in the fringe, and NEVER on digital. As I mentioned above, it seems like a problem with the radios presumption of what the RSSI is because it will suddenly mute and resume scanning with one or two bars still showing. At other times one or two bars will come in fine and is often readable. Basically what K2NEC also described.
Floridarailfanning
East Tennessee
I just reread the OP's first post again.
I have the bandwidth set to 25 for the channel in question and I compared it to another XPR7550 (not an e) with the same exact channel specifications (bandwidth 25, etc etc.) and that radio does not have any cut off.
I could be mistaken but unless the NYPD weaseled their way out the narrow-banding mandate in 2013, you need to be using 12.5kHz NOT 25kHz.
GTR8000
NY/NJ Database Guy
BEE00
NYPD operates in the T-Band, which was exempted from narrowbanding by FCC waiver two months after the Middle Class Tax Relief and Job Creation Act of 2012 was passed by Congress (i.e. the legislation which calls for the T-Band giveback). No one "weaseled their way out" of anything.
Floridarailfanning
East Tennessee
Well, I just learned something! I only deal with VHF High so didn't know that.
alcahuete
Must be nice. . .
Yeah...I wish I had an answer for you. I use analog simplex on these radios all the time, probably more than I do digital, and just don't have that problem at all. I don't know what the issue might be.
KG4INW
Midlothian, VA
I've worked with all manner of TRBO radios over the past 8 years (as part of my job), analog, digital, repeated, simplex, etc. The only time I've had obvious problems, were when parts failed or there were alignment issues. I suggest putting your radio on a calibrated service monitor to see how it functions when you can completely control the RF parameters and compare to your other radio.
RRR
OFFLINE
USA
Love my 5550 and 7550, but when changing channels, they are sllllooowwwww
K2NEC
NA
Agreed. It helps to turn scan off but still, it takes a hot minute for me to see what channel I am on if I go too fast.
  • Like
Reactions: RRR
