XPR7580 Programming / Clone
giebelr
Ormond Beach, FL
I have a 7580 with a working cqodeplug using CPS2.0. I bought another 7580 and want to "clone" it using the same codeplug. When I try the clone function in 2.0, I get an error message that the serial number doesn't match. I'm assuming that it doesn't match the codeplug or the software connects codeplugs by serial number. Its no surprise that it doesn't match--its a different radio.
That being said, is there a simple "fix" for this? Open to suggestions. Thanks, in advance, for the stress reduction responses.
N4KVE
PALM BEACH, FLORIDA
I have 3 7580’s. When I cloned the newest one to the first two I had to make sure the “feature list“ was the same. Then when I hit clone it mentions the serial numbers are different, but it allows me to click the serial number of the slave radio, & the clone happens.
tgbanshee
NJ
This. I've run into this several times attempting to clone radios, CPS is picky about the feature list between radios. If the feature entitlements aren't the same, it won't let you perform a clone.
nokones
Sun City West, AZ
If the CPS application will not allow you to clone, then you can split your screens and launch the CPS Application on the second split screen and copy and paste from your source radio screen to your target radio screen. I think the Security section is the only section that cannot be copied and pasted from one to the other.
K9KLC
Southwest, IL
I agree with this. You can copy the configuration from one to another. I think I had to redo the stuff in the scanning lists also when we did this using 2.0 if I remember correctly.
