XTL/XTS5000 XTL 1500 Accessory Pinout
wstorrs
Clifton Springs, NY
Good morning,
Looking to obtain some information for the Motorola XTL 1500 and the AVTEC Radio system.
We need the pinout information for the XTL 1500 radio to interact with the system.
They sent me wiring schematics and say it’s a 4 wire system. (See attached)
Any help would be appreciated.
wstorrs
Clifton Springs, NY
Did you even search. There are a ton of diagrams for J2 online. There are service manuals online.
Yes I did look it up (not that stupid) I am NOT a radio expert by ANY MEANS. I am just trying to complete a SIMPLE fix so my communications center can get back to normal operation. You have no idea what my position is, but if you are not going to be kind about commenting, I would appreciate if you could not respond. Thank you in advance.
jeepsandradios
East of the Mississippi
Sorry if your not a radio expert you should not be working on a radio for your communications center. Thats what radio shops are for. Motorola has a presence in Syracuse and Skywave is in Rochester. Either could quickly resolve your issues. What your asking for is not a simple fix as you need pins for J2 and as stated above its not balanced audio. If your going to the outpost they make a specific cable for that interface.
nikronzo
Cable is easy to make, if you are comfortable with crimping J2 pins and populating the connector.
Avtech Rx+ to J2 Pin21
Avtech Rx- to GND Pin 1 or 14
Avtech Tx+ to J2 Pin 23
Avtech Tx - to GND Pin 1 or 14
PTT to J2 PTT Pin 16
PTT Gnd to J2 Gnd 1 or 14
