XTL 2500 Audio Out
Dxj100
I currently have a XTL 2500 with a small external speaker. I am looking to add a remote speaker in a shop bay. I would like this to have its own volume control so the office speaker does not have to be adjusted to adjust the bay speaker. I have seen that port 21 can be used for this.
My question is what else would be needed? I know I would need a small amp to accept this audio input and feed my shop speaker.
I also saw that you can not ground the audio output loop but going to a small amp should be ok correct? Can someone let me know how to wire it up?
I am guessing I would go from pin 21 to pos in on amp and from pin 1 to the neg in on the amp. Then just hook my speaker to that. Or do I need something between the radio and amp?
Would something like a cheap 2 channel home audio amp from Amazon be appropriate for this?
Thanks for you help.
a417
get a small 70v power amp, and put adjustable tap transformer speakers in each location. Do it once, do it right.
Something similar to this to feed from your radio, this for the office, and then something like this for the bays. The adjustable transformers and pots on the speakers will allow you to tailor sound output to your situation. I'm only giving you links to Bogen equipment, as it's all I've ever used. One could find equivalent for a moderately lower price if so inclined, but Bogen has always just worked. Filtered audio out from the radio to the amp, and let the amp do the dirty work.
