XTL 2500 Cables
K2NEC
NA
xtl2500 only has one model head!
For the OP. you will meed a remote head cable and a power cable for the control head.
The XTL2500 actually has two compatible heads, the O5 and the M5. I think that's what he was asking. Regardless, they use the same cables
FFPM571
Nashvillle
The data cable( blue connector) , Head power cable( red connector)n with the red, yellow and black wires with the speaker plug, External speaker and Main Red /black power cable. If you need any of them I have all of them you can contact me
nikronzo
This is misleading, the M5 head is the only officially supported control head. Sure you can "convince" the 2500 to be a 5000 through tools or change the pad on o5 head to become a M5. However, if you put a o5 head on an XTL2500 without any modification of either component, they will not work and you will get a CH MISMATCH error.
nikronzo
As to the OPs question, you are going to need the HKN6169B which is the control head data cable and HKN6188 for the control head power cable.
n3obl
Ø
PA
Yes you can not use an O5 without modification. I will correct myself there is a setting in special CPS software called Intl Control head support which if enabled will allow an xtl2500 deck to use an o3 HHCH.
