XTL 2500 Cables
nokones
Sun City West, AZ
Please forgive my ignorance, but I have never dealt with a remote head XTL. I recently received a remote mount XTL 2500, with zero cables. Does anyone have a list of required cables?
Which control head do you have?
n3obl
ØAES-1056
PA
xtl2500 only has one model head!
For the OP. you will meed a remote head cable and a power cable for the control head.
K2NEC
5F6
The XTL2500 actually has two compatible heads, the O5 and the M5. I think that's what he was asking. Regardless, they use the same cables
FFPM571
The Mid South
The data cable( blue connector) , Head power cable( red connector)n with the red, yellow and black wires with the speaker plug, External speaker and Main Red /black power cable. If you need any of them I have all of them you can contact me
nikronzo
4.X SloppyCast
This is misleading, the M5 head is the only officially supported control head. Sure you can "convince" the 2500 to be a 5000 through tools or change the pad on o5 head to become a M5. However, if you put a o5 head on an XTL2500 without any modification of either component, they will not work and you will get a CH MISMATCH error.
nikronzo
4.X SloppyCast
As to the OPs question, you are going to need the HKN6169B which is the control head data cable and HKN6188 for the control head power cable.
n3obl
ØAES-1056
PA
Yes you can not use an O5 without modification. I will correct myself there is a setting in special CPS software called Intl Control head support which if enabled will allow an xtl2500 deck to use an o3 HHCH.
