XTL 2500 firmware upgrade path
kb2ear
New Jersey
I have a bunch of old radios that are moving from P16 to P25, they are all on V08.01.03 currently. I bought a bunch of flash upgrades before they went EOL and I have the key. I know if I go straight to V20 I will loose connectivity with the control heads. Does anyone have the safe procedure to upgrade?
Can I upgrade the head and brick separately so auto upgrade does not need to happen?
Giddyuptd
Here and there
If I recall I believe the steps in versions were 4, 8, 14, avoid 17, then 21. I know we had gone from 14 direct to 21.xx no issues. It would be when the versions had major changes in them
Echo4Thirty
Spring,TX
The device you plug into gets the firmware updated first, so in your case it might be wise to plug into the mic port on the control head. You will also need to use serial as opposed to USB with a starting firmware that low. I forget what version added USB support, but we have radios at version 12 that we have to flash with serial to get them up to 20.50.10.
