XTL/XTS5000 XTL5000 firmware upgrade
wgbecks
NE Wisconsin
Good info, I've never had my hands on a high power deck - didn't know that. Thanks! Good to know that the always-reliable RS232 connection is still there, albeit at different connection points and pin #s.
There's the HKN6183 High Power CGAI to RS232 cable available, but I thought I'd suggest using J6 in that the OP already has a DB25
attached to this connector (Post #12) and could easily add a few more wires to facilitate a serial communications channel.
Truthfully, I am not convinced that his existing GCAI USB cable won't work to upgrade the firmware but would want to query the radio using
a simple terminal program to probe around in the radio.
merlin
DN32su
HLN6901D != HLN6885B.
There could be an issue with the antique firmware not liking that TIB you have. The DSM does list HLN6901(x) as an option, but it may have been a late in life change on the unit, so it would need later firmware to support it.
Just my opinion, what you have clearly isn't working for programming. Have you tried depot to the J2 via serial yet?
Actually, programming is not a problem, but I tend to agree this firmware is not ideal for this hardware.
That is why I am trying to update and that so far has failed.
The OP’s radio is a “High Power” model and does not have the normal J2 accessory connector.
@merlin, you might try adding a few additional wires to the DB25 that you've attached to the J6 connector on the TIB to provide
Serial RS-232 communications equivalent to that of the HKN6122 Data Cable per the wiring shown below.
I have what is needed to try this. In testing, the RS232 signals look good on J6. Maybe I can get Depot to connect here.
I had already thought of seeing what I can get with terminal commands. Just busy with this other stuff.
At least this front RS232 is the same as the J2 equivalent.
Some good things to try, Thanks.
wgbecks
NE Wisconsin
Send me a PM if you still have issues with Depot once you connect up to the RS232 on J6. I might be able to assist.
merlin
DN32su
OK, the J6 RS232 checks out and finally will connect with Depot. I do get this odd unexpected version error, but that should be easy to overcome.
The codeplug was built with CPS 20.01
My Depot version is 15.00.00 (all I had in my stockpile.)
