XTL 2500-HMMWV
candlercoso
Metter, GA
I have an XTL 2500 mounted in a Hummer. I am looking for an adapter that will accept the NATO headset plug for Peltor headsets to route audio from the radio to the headset. Any advice will be greatly appreciated.
J
nokones
Sun City West, AZ
J
There are several suppliers that will make a custom adapters for you. To name a few Klein Electroncs, Planet Headset, and Racing Electronics, and Setcom. PVP Comm. used to do custom builds, not sure if they are back doing custom builds again or not.
prcguy
If you can purchase a female cable mount headset socket there is mic audio, PTT and ground available on the rear panel accy connector. You probably already have an accy plug with a speaker wire and ignition wire attached to your radio and you can get accy pins off eBay and add a cable to feed your headset. NATO plug wiring is available with a search as is the XTL accy pinout. Or you can cut the cable off a spare mic and wire that into a headset socket and mic pinouts are also easy to find.
If you can read diagrams and solder you can save a bunch of $$ as commercially made adapter cables are pricy.
