XTL 5000DB25 pin out
P25Radio
Oceanside Ca.
I have a XTL5000 VHF 110watt radio with a 03 head given to me from a friend while cleaning out a storage unit he purchased. I can read and write the radio with a 05 head works great. 03 head I have is new but I need to make a connector for the db25 accessoray for ingition switch and speaker output on the brick side. I do not have a manual yet for the radio, Can I get a pinout picture please, I want to run the mic up front as the control head.When the 03 head is connected to the brick I can turn the radio on, green light on mic works but radio does not come alive.
radioman2001
New York North Carolina and all points in between
Go to Repeater Builder and look for Astro Spectra diagram for the dual DB-25, they are close to the same. Otherwise you will have to look elsewhere for the single DB-25 version, which I am not sure if it supports O-3 heads. There is a lot of extra parts on the 0-3 interface board that has to do with power up.
P25Radio
Oceanside Ca.
No, this is the one on the radio it self. Only connections on the radio are Antenna,12V SAE, 2 blue for remote mount operation,1 red and the DB25 Female socket. Looks like a Spectra DB25 say to plug in a siren ect.
I tried to upload a picture said file was to big. The plug on the right side of the radio.1545094128756.png
P25Radio
Oceanside Ca.
After some really serious searching this is the correct pin assignment for the 110w xtl 5000's db25 connector on the radio, not the 26 pin on the back of the control head. My buddy works for "M" and installs and this is what he stated.
J600-1 AUX_PTT
J600-2 RS232_RX= UARTA_TX= DCE_TX
J600-3 RS232_TX= UARTA_RX= DCE_RX
J600-4 RS232_RTS= UARTA_RTS= DCE_CTS
J600-5 BUS(+) (SB9600)
J600-6 RX_AUDIO
J600-7 AUX_RX
J600-8 AUX_TX
J600-9 RX_AUDIO
J600-10 GND
J600-11 GND
J600-12 DAC_OUT
J600-13 EMERGENCY
J600-14 BUS(-) (SB9600)
J600-15 VIP_OUT_1
J600-16 IGN
J600-17 RS232_CTS=UARTA_CTS=DCE_RTS
J600-18 GND (legacy)
J600-19 RESET (SB9600)
J600-20 A+
J600-21 GND (SHIELD)
J600-22 SW_B+
J600-23 BUSY (SB9600)
J600-24 SPEAKER(-)
J600-25 SPEAKER(+)
