XTL/XTS5000 XTL5000 flashcode "_APPL5_"??
K2NEC
5F6
Exactly my thoughts. Which is why I am very confused lol
secureradio01
This is in fact a valid tag. I have a couple of these in our shop that came from an agency in California, I believe it is an application flashcode for a radio that has been sent back to the depot at one time for repair or a special application testing radio. It is uncommon, but they do exist. I have only seen these come from the LA County and San Diego County areas. I have a couple in UHF R2 band and a few in 700/800mhz. All of the ones I have are exactly the same flashcode in them regardless of band 500008-000000-1 and they all have DVP-XL Encryption in them.
K2NEC
5F6
Oh ok cool I never knew that. And not for nothing but that's a pretty flavorless flashcode lol
Thanks for the cool tidbit of info
SuperG900
WG5ENE
Edgewood, NM, USA DM65vb
Custom firmware options are common in any radio based gear these days.
Some of the RFID transponders I worked on, licensed 800 & 900MHz ISM stuff had maybe 20 options. A lot depended on on regulatory jurisdiction, which varies worldwide. Sometimes, a configuration option wasn't quite possible for a particular use case and a custom firmware (actual custom code - not config options, ala "codeplugs" etc). would be needed. Those units would be the ones with the weird, one-off, serial numbers.
hitechRadio
No, custom firmware is not common in radio's..it is uncommon, especially in public safety radio's. This flash option _APPL5_ has nothing to do with firmware.
SuperG900
WG5ENE
No, custom firmware is not common in radio's..it is uncommon.
You're probably be right in respect to LMR - I forgot that my personal experiences are in the ISM markets where it's mostly data transmission and the need for integration with a customer's data systems (computers and/or network) - and needs vary. Wildly. We try to design a system that'll cover most bases - but there's always one that out there, and if we can make a buck on it, we'll do it.
