XTL5000 P25 Programming
dryfb
Midwest
Are you transmitting a talk group? I'll be honest idk much about P25 conventional TGs, especially on Moto but the repeater may require one to open up.
I am able to bring up UHF repeaters with no issue. I checked power levels and they are where they should be. How important is the $ in the NAC? I tried placing it in the CPS but it would not take it…..I will continue plugging along, and also have someone else look at my settings.
Based on that, I'd say your power level is good and it's close enough to being on frequency that it's not an issue for 25kHz analog. Since the P25 is running 12.5KHz, frequency accuracy is a bit more important, but I'd hold off sending it in for alignment right now.
F7E is fine, if that is what the radio wants. That should make the RX side run like analog carrier squelch mode, it should open squelch for any received P25 signal.
Do you know if the repeater owner has it set up to be expecting specific/registered radio ID's?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
The '$' is simply to indicate that 'F7E' is a Base 16(Hex) number, not a Base 10. The '$' is not entered in the NAC part of the software. Only 3 digits, numbers 0->9, and letter A->F are valid enteries for a NAC. Think of NAC as doing the same job as CTCSS, but instead of ~50 CTCSS tones, there are 4096 valid NAC codes, although a few have very specific uses in the P25 CAI protocol.
Have you set up a Conventional ASTRO System, and a Conventional ASTRO Personality under the respective parts of the codeplug?
Is this repeater using any talkgroups other than the default of 1? If you don't know, you need to find out.
In the Zone/Channel part of the codeplug, Have you selected the ASTRO personality for the specific channel you are trying to program for the P25 repeater?
In the channel you are programming, you need to input the receive frequency, transmit frequency and the correct NAC codes for both transmit and receive. You also have to select your ASTRO personality.
