thisguyneedsabeer
- Joined
- May 20, 2020
- Messages
- 112
- Reaction score
- 32
Hello, I recently ordered a secondary surplus XTL5000 with the O5 head from a surplus shop I have ordered more than a few XTS/XTL5000's from in the past without issue. The first thing I noticed with this radio was that it was on R09.00.00 FW, I had that upgraded to the latest R20.50.10 to match the other radio. No issues during that process. Here's where I started noticing some nuances.
- When the radio is read, it immediately turns off after being read in by the CPS. I am using an official Motorola HPN4007D power supply.
- This also occurs when writing the radio
- Power Supply has been working for my original base radio for at least a year without issue.
- I cloned my known good XTL5000 (A) into the new XTL5000 (B), they have the same codeplug and firmware. When I key up on my frequency/talkgroup pair (strapped TGID to a conventional personality) on radio A, my hotspot picks up the P25 traffic and links, unlinks, behaves as it should. When I perform the same action on radio B, the hotspot does not receive the traffic.
- Both radios are programmed IDENTICALLY, with the same ID, the hotspot is not in private mode.
- Radio <-> radio over simplex seems to work just fine.
- Both radios have an Antenna with an SWR of 1:2.1:3 at most.
- Tried using all of the cables from the known good radio to rule out any issues with the cables purchased for the new radio. No change.
- Tried using the mic from the known good radio to rule out any issues with the used mic. No change.
- Tried a brand new blank code plug and programming a single frequency and talkgroup and strapping it to a conventional personality. No change.
- Tried changing the hotspot frequency and programmed the radio to TX/RX on the same frequency. No change.
- I talked my a semi-local repair shop and they said they could do a $45 diagnostic + whatever parts/repair are needed. My questions are:
- Is there anything else I can do from my end?
- What could cause this behavior? I am eager to learn, but unsure of what resources other than searching forums are available to me.
- I assume this is a reasonable fee for an aging radio, does anyone think otherwise?
